ciao,
vendo 2 server (uguali) dalle seguenti caratteristiche:
NetStrada 5400 Plus
Case Tower.
1x3.5" For Floppy disk (front accessible).
6x3.5" For Hot-Swappable HDU.
3x5.25" For Removable.
Power Supply Autoranging, Hot-Swappable and Optionally Redundant (ovvero possono essere collegati 2 alimentatori in serie in modo da sommare la loro effettiva potenza (=Optionally Redundant) e possono essere scollegati (uno alla volta) a caldo, cioè a computer acceso, (Hot-Swappable)).
Redundant Cooling (ventole di raffreddamento) 1x 120mm fans for electronic card (massimo 6 ventole possono essere collegate direttamente) and 3x 60mm fans for HDU Bays.
2 thermal sensor, with remote monitoring via Server View
alimentatore Magnatek Potenza Max: 1x 450w Power Supply Autoranging, Hot-Swappable
Caratteristiche:
+3.3v 15A
+12v 18/27A
+5v 50A !!!
MotherBoard ( Scheda Madre )for Single or Dual INTEL Pentium II or Pentium III da 300 MH in su. ATX.
CHIPSET : Intel 82440BX
BIOS: 512 KB , Flash EPROM - Tipo: NIGHTS0.86B.0095 - Versione: P14
SYSTEM MEMORY: 4 memory banks from 32 MB to 1 GB ECC Protected
DIMM SDRAM ( Synchronous Dynamic RAM ) – 168pin - 100 MHz 3,3 V .
INTERFACES ON MOTHERBOARD:
Serial: 2 Port buffered COM 1/4 configurable D shell 9/10 pin connector
Parallel: One Port IEEE 1284 compatible bi-directional
Keyboard and mouse: Standard PS2
EIDE: Controller Two channel ATA 33
FDU : Standard
SCSI : Dual channel UW SCSI controller ( SYSMBIOS 53C876 )
LAN : Intel PRO/100+Mgmt 10-100 MB compatible LAN controller with
Wake-Up on-LAN functionality
GRAPHIC SUBSYSTEM: CIRRUS 5480 2D high performances video controller on M.B.
Video memory 2 MB
ADVANCED EMERGENCY MANAGEMENT PORT ( EMP ): Present for remote access via external modem.
EXPANSION SLOTS: 3 PCI , 1 ISA , 1 PCI/ISA ( shared )
A.S.R. ( automatic Server Restart ): YES
U.P.S. : YES (APC Smart UPS)
Controller raid SCSI PCI:
AMI MegaRaid Express Series 466 Rev-B
Modello: American Megatrends Inc. (AMI) Express 200 series 466 is a PCI single channel Ultra2 LVD/SE SCSI RAID controller card. Pulled from working Dell server
Series 466 - MegaRAID Express Plus (Express 200)
Collegamento: PCI
Foto: http://www.inticleanbidet.com/ebay1...0Raid%203-s.JPG
http://i7.ebayimg.com/01/i/02/3b/35/41_1_b.JPG
http://i5.ebayimg.com/03/i/02/62/69/8e_1_b.JPG
Caratteristiche:
PCI Ultra2 LVD RAID Controller
Supports up to 15 Devices per Channel
Fault Tolerance
RAID Levels 0, 1, 3, 5, 10, 30 & 50 Supported
PCI Bus Master with Burst Data Transfer Rate of 132 MB/sec
Cache Configuration: 4, 8, 16, 32, 64 or 128 MB using 60ns Cache Using One 72 Pin SIMM Bank Symbios Logic 53C895 (LVD/SE) SCSI Processor
Supports Ultra2 Speeds of 80 MB per second
SMART (Self Monitoring and Recovery Technology)
I2O (Intelligent Input/Output) Support
Cpu: Intel i960®RP 32 bit RISC Processor @ 33 Mhz
Bus Type: PCI 2.1
Write Through or Write Back on a Logical Drive Basis
Adaptive Read-Ahead
EDO or FPM SIMMS
AMIBIOS® RAID Firmware on Flash EPROM
Non-volatile RAM Stores RAID Configuration
Tone Generator Provides Audible System Warnings
Half Length PCI Footprint (7.5" x 4.2")
SCSI Cable Lengths of up to 25 Meters with LVDS Drives
Low Voltage Differential or Single Ended SCSI Bus with Active Termination (LVD)
Automatic Termination Disable via Cable Detection
Single 68 Pin High Density Internal Connector
Tagged Command Queuing
Supports Scatter/Gather
Multi-Threading of up to 256 Commands Simultaneously
Multiple Rebuilds and Consistency Checks with Transparent and User Definable Priority
Variable Stripe Size for All Logical Drives
Supports up to 6 Non-disk Drives per Adapter
Connectors: One 68-pin internal high-density connector for 16-bit SCSI devices. One ultra-high density 68-pin external connector for Ultra and Wide SCSI.
Bus Data Transfer Rate: Up to 132 MB/second for the PCI Bus transfer rate
SCSI Data Transfer Rate: Up to 80 MB/second
Gateway Default Configuration: 8MB EDO 72-pin SIMM (sostituibile con un’altra simm 72pin - Up to 128 MB Cache Using One 72 Pin SIMM Bank)
Processore RISC i960:
Intel's i960® processors offer a broad line-up of code-compatible products for fast time-to-market in networking and imaging applications. The i960 architecture family consists of high-performance, 32-bit embedded RISC processors supported by an outstanding selection of development tools.
The entire line is code-compatible offering a wide range of performance options, giving developers an easy migration path while preserving investments in existing hardware and software. It is a time-proven and excellent choice for local and wide-area networking, telecom and imaging applications.
Lettore Dat Sony
Modello: SDT-9000
Foto: http://www.odynet.it/catalog/images/sony11000r.jpg
Caratteristiche:
DDS-3 Internal Drive
buffer di 2 Mbyte
24 GB capacity and 2.4 MB/s sustained data transfer rate (with 2:1 compression)
Sony Hyper MetalT Head reduces error rate compared to conventional ferrite MIG heads
Backward compatible to DDS-2 and DDS-1 format
Sony's patented Super Head CleanerT mechanism reduces particle build-up on read/write heads
High reliability with 200,000 POH MTBF at 20% duty cycle
Descrizione:
SONY SDT 9000 e' un'unita' di backup a nastro, di tipo DAT (Digital Audio Tape), con interfaccia Fast-SCSI2. La tecnologia DAT e' basata sulla registrazione di tipo digitale, e consente di memorizzare fino a 24 Gb (in modalita' compressione dati abilitata) in un'unica cassetta. L'interfaccia Fast SCSI2 (che necessita di un apposito controller Fast SCSI2 o superiore) consente velocita' ancora superiori rispetto ai precedenti modelli, essendo in grado di arrivare fino a 2,4 Mb/sec di transfer rate massimo, sfruttando un buffer di 2 Mbyte. Indicato non solo per grandi stazioni di lavoro (come ad esempio server di rete), ma anche per chiunque abbia semplicemente necessita' di lavorare con grandi moli di dati (es. multimediale, filmati, fotoritocco, etc.), SONY SDT 9000 e' la soluzione ideale, che risponde a requisiti di sicurezza dei dati, velocita' di trasferimento e ampio spazio di memorizzazione. Ha un'affidabilita' (MTBF), dichiarata da SONY, di 200.000 ore. A conferma della sua qualita', incorpora il brevetto "Super Head Cleaner (TM)", per la pulizia delle testine, e un sistema di autoverifica dei dati scritti. Supporta nastri da 60, 90, 120, 125 m.
Cartucce Dat:
Marca: IBM
Tipo: Storage DAT
Capacità: 4gb / 8gb (media/compressa)
Link:
http://www.epinions.com/pr-IBM_8191...lay_~full_specs
li vendo ciascuno a 250 euro.
in + ho questi "accessori" per completare la configurazione:
6x Hard disk: 30 euro Cad.
marca: Fujitsu Limited
Modello: MAE3091LC
Caratteristiche: Hard drive - 9.1 GB - hot-swap - 3 1/2" 7200 RPM
Collegamento: 80 pin SCA2 Connector
Protocollo: Ultra 160 SCSI (compatibile a ritroso, consigliato almeno Ultra 2 Wide SCSI )
Tipo: Hot Swap
Transfer Rate Max: 160 MBps (16-bit)
SCSI Signaling Type: Low Voltage Differential (LVD)
Prezzo di Listino: 160 euro Cad.
Link:
http://sunsolve.sun.com/data/805/80...pdf/001.9GB.pdf
http://www.simpaticotech.it/dettagl..._sub_categorie=
Codice: MAE3091LC
Produttore: SIEMENS
Sito Produttore: www.fujitsu-siemens.com
3x Ram: Dimm SDRAM 128MB PC100 168pin ECC Cas2 222 - 25 euro ciascuna
2x CPU: Intel Pentium III 550mhz 512k L2 cache 2.0v con dissipatore passivo – 15 euro ciascuna
2x Block CPU: da inserire nello Slot 1 della scheda madre. Serve per utilizzare il server con un singolo processore benché la scheda madre possa utilizzarne due. – 10 euro ciascuna
sono usati, ma li ho completamente testati e sono sicuro del loro funzionamento! per altre domande scrivetemi pure!
ciao,
shin82! :twisted:
(MI) vendo 2 server professionali
Regole del forum
- shin82
