consiglio nuove ram
consiglio nuove ram
Messaggio da wasky »
volevo acquistare alla fine del mese un kit dual pack , considerazioni e critiche da parte vostra aiuteranno nella scelta, vi ringrazio in anticipo per l'aiuto e passo ad elencare i prodotti bramati:p :p :p :p anticipando ke sia mushkins e geil hanno i bh-5 :wink:
GEIL DRAGON PC 3500[
GeIL Golden Dragon PC3500 433MHz Dual Channel DDR Kit
Available only in 512MB (2X256MB) and 1GB (2X512MB) Dual Channel DDR Kits
184pin, Non-ECC, Un-buffered, high performance DDR memory modules.
Hand Picked GeIL 4.5ns 32x8 Density WLCSP DDR Chip with Gold 30u" Plating.
6 Layers Ultra Low Noises Shielded Golden Dragon PCB.
Dragon Eye: One red led on PCB board for memory module ON/OFF detection.
Optimized SPD for Dual Channel DDR motherboards.
Lifetime Warranty .
CAS 2 6-3-3 1T @ DDR433 PC3500
2.55V-2.95V
GEIL PLATINUM DUAL KIT PC3500
GeIL Ultra Platinum PC3500 433MHz Dual Channel DDR Kit
Available only in 512MB (2X256MB) and 1GB (2X512MB) Dual Channel DDR Kits.
GeIL 4.5ns 32x8 Density DDR Chip.
6 Layers Ultra Low Noises Shielded PCB with Gold 30u" Plating.
Platinum Copper Heat Spreader.
Lifetime Warranty .
CAS 2 6-3-3 @ DDR433 PC3500,
2.55V-2.95V
MUSHKINS PC 3500 SINGLE Pack x 2 LEVEL ONE BLACK
http://www.mushkin.com/epages/Mushkin.s ... iew/991090
