Vendo scheda madre ECS P4S5A-DX+ e cpu Intel Celeron 2400 mhz con dissipatore perfettamente funzionanti.
Socket 478 board that supports Intel® Pentium® 4 e Celeron processor
Front Side Bus 400 e 533 MHz
Integrated with the most advanced technologies:
LAN wake up
Magic setting
Keyboard power on
USB 2.0 (SiS® 962L)
With USB 2.0 host controller integrated in SiS® 962L chipset, this board provides the data transfers of 480Mbps to satisfy the most demanding peripheral and applications in today's PC market.
CHIPSET
SiS® 645DX & SiS® 962L chipset
SiS® 645DX host/memory controller with DDR333 and AGP4X North bridge single chipset
SiS® 962L MuTIOL media I/O
Integrated USB 2.0 host controller
LPC I/O: ITE IT8705F
System Hardware Monitor: Built-in ITE IT8705F
LAN: 10/100 Mbps faster Ethernet
AC97 Audio Codec: Compliant with AC97 2.2 specification
SYSTEM BIOS
AMI 2Mb flash EEPROM
Supports Plug and Play 1.0A, AMP 1.2, multi boot, DMI
Support for ACPI revision 1.0 specification
MEMORY
2 DDR DIMM sockets and 2 DIMM sockets support
Two 184-pin 2.5V DDR SDRAM (DDR333) or
Two 168-pin 3.3V SDRAM (PC133/PC100)
Maximum: 2GB (DDR SDRAM or SDRAM)
I/O INTERFACE
Supports Plug and Play function
PS/2 keyboard and PS/2 mouse connectors
4 USB ports and an optional LAN connector
1 EPP/ECP mode parallel port
2 16550 high-speed serial I/O ports
Audio ports (Line-in, Line-out, Mic-in, CD-in and game port)
Dual PCI IDE interfaces - support four IDE devices (PIO mode 4, DMA mode 2, Ultra DMA 66/100/133)
Supports 360K~2.88M Byte, 3 mode FDDs or LS120
ATX power supply connector
Ports, headers and others:
IrDA header
Front panel Mic./Line-out header
2 extra USB ports (USB1)
HDD LED, Reset switch, Power switch headers
CPU and system fan headers
LAN card wake up header
RTC & BATTERY
SiS® 962L built-in 256 bytes of CMOS SRAM
With CMOS hardware clear jumper
EXPANSION SLOTS
5 PCI slots, 1 AGP slot, 1 AMR slot
FORM FACTOR & LAYERS
ATX (305mm*244mm), 4 Layers
Caratteristiche CPU
Speed = 2400 MHz
System Bus = 400 MHz
Intel MMX Technology = si
CPU Type = 0
CPU Family = F
CPU Model = 2
CPU Stepping = 9
CPU Revision = 21
Cache L2 = 128 kb
Cache L1 = 8 kb
Packaging = FC-PGA2
Scheda madre a 30 euro escluse spese di spedizione
Cpu Celeron a 30 euro escluse spese di spedizione
Se comprate in blocco le spese di spedizione gratuita con pacco celere 3
[EN + spedizione] vendo MB e cpu intel
Regole del forum
- favola1021
