Name AMD Athlon XP
Code Name Thoroughbred
Specification AMD Athlon(tm)
Family / Model / Stepping 6 8 1
Extended Family / Model 7 8
Package Socket A
Core Stepping B0
Technology 0.13 µ
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE
CPU Clock Speed 2088.1 mhz
Clock multiplier x 12.5
Front Side Bus Frequency 167.0 MHz
Bus Speed 334.1 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 256 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 2088.1 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 64 bits
Ho messo mano al BIOS per la 1° volta e ora non funge piu'..
