joystick playstation con usb
grandegino
Messaggio da grandegino »
vi propongo questi schemi:
Sony Playstation Controller Port
Pin Name Description
1 DATA Data marrone
2 CMD Command arancio
3 N/C (9 V unused) Not connected
4 GND Ground nero
5 VCC Vcc rosso
6 ATT ATT select giallo
7 CLK Clock blu
8 N/C Not connected
9 ACK Acknowledge verde
Signals description:
DATA
Signal from Controller to PSX. This signal is an 8 bit serial transmission synchronous to the falling edge of clock (That is both the incoming and outgoing signals change on a high to low transition of clock. All the reading of signals is done on the leading edge to allow settling time.)
COMMAND
Signal from PSX to Controller. This signal is the counter part of DATA. It is again an 8 bit serial transmission on the falling edge of clock.
VCC
VCC can vary from 5V down to 3V and the official SONY Controllers will still operate. The controllers outlined here really want 5V. The main board in the PSX also has a surface mount 750mA fuse that will blow if you try to draw to much current through the plug (750mA is for both left, right and memory cards).
ATT
ATT is used to get the attention of the controller. This signal will go low for the duration of a transmission. I have also seen this pin called Select, DTR and Command.
CLOCK
Signal from PSX to Controller. Used to keep units in sync.
ACK
Acknowledge signal from Controller to PSX. This signal should go low for at least one clock period after each 8 bits are sent and ATT is still held low. If the ACK signal does not go low within about 60 us the PSX will then start interogating other devices.
USB Cable colors:
Pin Name Cable color Description
1 VBUS Red +5 VDC
2 D- White Data -
3 D+ Green Data +
4 GND Black Ground
Voltage:
• Supplied voltage by a host or a powered hub ports is between 4.75 V and 5.25 V.
• Maximum voltage drop for bus-powered hubs is 0.35 V from it's host or hub to the hubs output port.
• All hubs and functions must be able to send configuration data at 4.4 V, but only low-power functions need to be working at this voltage.
• Normal operational voltage for functions is minimum 4.75 V
ho provato a fare qualche collegamento ma il computer mi dice periferica non riconosciuta. VOI POTETE INVENTARVI QAULCHE COSA?[/img]
