1)
ragazzi qualcuno sa dirmi com'è questo dissipatore?
GH-PCU21-VG
(3D Cooler-Pro)
Cool
Central-Blower
360 ° Cooling Architecture
Double Inlet from Top and Bottom
Silent
PCB for Linear Fan Speed & Noise Control
Fan Speed Control on Panel (suitable for both 3.5" front panel PCI rear panel)
Light
High Density Hollow Fins with Embedded 4 way Heat Pipes
Total Weight of 430g
Attractive
Unique Heatsink Structure
Eye-Catching LED Display
Universal
Compatible with Intel® Pentium® 4 and AMD Athlon™ 64/ Athlon™ XP
Tool-Free & Easy to install
Detail Spec.
Heatsink Dimension 83 x 89 x 93mm
Rated Voltage 5~12V
Rated Current 0.5A
Fan Speed 2000~4000rpm
Noise 19.2~37.2dBA
Bearing Type 2 Ball bearing
Life Expectancy 70000Hr
Total Weight 430g
Application Intel® Pentium® 4 478 up to 3.4GHz and higher
AMD Athlon™ XP up to 3200+ and higher
AMD Athlon™ 64 up to 3400+ and higher
Package Contents GH-PCU21-VG Cooler
Heat sink paste Injector
Fan Speed Control and 3.5" Front Panel
PCI Rear Panel
Power Cable
Intel® Pentium® 4 Clips
AMD Athlon™ XP Clip
AMD Athlon™ 64 Clip
Screws
mi sa che è un pò enorme....
caso mai qualche consiglio per un dissi?
guardate la config nella firma.....
a me interessa qualcosa che mi tenga la temp bassa in oc quasi nulli....amd 3000@3200....
2)
ho scaricato questi 2 driver
Sis AGP Driver 650/651/661/740/741/760 3.65 WHQL
This package include five parts.
1. WinXP/Win2000 AGP filter driver: Which can support AGP 8x chipset if chipset and VGA card support.
2. WinME/Win98 AGP miniport driver:Which can support AGP 8x chipset if chipset and VGA card support.
3. Some Windows patches:
SIS_LIB.DLL,SISPORT.SYS (winxp) : they are used for reading PCI port.
SiSUSBrg.exe (winxp): Add registry for USB bug under WinXP
Mp_s3.exe (WinME):Patch old SiS 961 FERR bug
Openhci.sys (Win98):Provided by Microsoft to update Win98 USB OHCI
4. Execute ata133.exe for IDE to let IDE support UDMA 133 (XP) and 48bit Capacity of HD.It also set IDE device to run UDMA as possible.
5. SisAGP utility setting AGP transfer rate only used in SIS AGP new driver
via_hyperion 4in1_v455vp1
come da config ho una ecs 755-a2
vanno bene?
li installo?
grazie
dissipatore
- jandg
- Contuso
dissipatore
