Steal A Brainrot Mythic Explained: Buy Brainrots from the U4N Website and Understand Tracoducotulu
Ruby
Scheda madre: 1
CPU: 1
Ram: 1
Scheda video: 1
HD: 1
Alimentatore: 1
Raffreddamento: 1
Sistema operativo: 1
Monitor: 1
Messaggio da Ruby »
What is Tracoducotulu Delapeladustuz?
Tracoducotulu Delapeladustuz is a Mythic Brainrot in Steal A Brainrot that was released on August 15th, 2025. In general, Mythic Brainrots are long-term assets rather than short-term tools, and this one follows the same pattern. Most players see it as a steady income option rather than something that instantly changes their progress.
It currently sits as the eleventh most valuable Mythic Brainrot in the game. It falls behind higher-ranked options like Carloo, Carrotini Brainini, Cachorrito Melonito, and Centrucci Nuclucci, but it still holds its place because of consistent income and its presence on the red path spawn rotation.
The base cost is $4.2M, and it generates $12K per second once secured at your base. Usually, players who go for Tracoducotulu Delapeladustuz already understand how stealing mechanics work and are prepared to defend it.
Why Do Players Care About This Brainrot?
Most players care about Tracoducotulu Delapeladustuz for three main reasons: rarity, income stability, and trading pressure. As a Mythic, it does not spawn frequently, so seeing one appear on the Red Carpet already attracts attention from multiple players.
In practice, it is not the best Mythic in terms of raw income, but it is often easier to justify than higher-priced Mythics. Players who are still building toward top-tier options usually consider this a midpoint goal. It pays for itself slowly and works well in bases that already have basic defenses.
Another reason players track this Brainrot is resale behavior. Some players collect Mythics not just to hold them, but to flip or move them later. This becomes relevant when people start discussing ways to sell brainrots for real money, even though that topic exists outside normal gameplay and carries its own risks.
Where Does Tracoducotulu Delapeladustuz Spawn?
Tracoducotulu Delapeladustuz spawns on the red path. In general, the red path is more competitive than other spawn routes because most Mythic Brainrots appear there. Usually, when one shows up, multiple players hover nearby waiting to buy or steal it.
Because of this, timing matters. Most players who successfully obtain it are already positioned near the Red Carpet and have enough cash ready. If you hesitate, another player may buy it first or overpay to redirect it.
How Does Buying This Brainrot Actually Work?
The first method is direct purchase. The base cost is $4.2M. Once purchased, the Brainrot begins moving toward the buyer’s base. However, this is not final.
Another player can buy it again for 150% of the base cost. When this happens, the Brainrot immediately changes direction and starts heading toward the new buyer’s base. This process can repeat multiple times, which often leads to bidding wars.
In real matches, most players do not let this go on forever. Usually, someone backs off once the price rises too high, especially if they are unsure they can protect it. Overpaying without defenses often leads to losing it through stealing.
How Does Stealing Affect Ownership?
Stealing is a core feature in Steal A Brainrot, and Tracoducotulu Delapeladustuz is no exception. The second main way to obtain it is by stealing it from another player’s base.
Most successful steals happen shortly after the Brainrot arrives. In general, players are most vulnerable during the first few minutes before defenses are fully active or upgraded. Experienced players often watch for Mythics that just arrived and target those bases.
Because of its high value, Tracoducotulu Delapeladustuz is rarely left unguarded. Players who lose it usually underestimated how attractive it is to others.
Is the Income Worth the Cost?
At $12K per second, Tracoducotulu Delapeladustuz offers solid but not exceptional income. Compared to top Mythics, the return is slower, but it is more predictable.
Most players who buy it are not expecting fast profit. In general, it works best when combined with other income sources. If it is your only major Brainrot, losing it can set you back significantly.
Usually, players who benefit the most are those who already have a stable base and want to add another reliable income stream without jumping straight to the most expensive Mythics.
How Does It Compare to Other Mythics?
Compared to Brainrots like Cocofanto Elefanto, Tracoducotulu Delapeladustuz used to be more valuable at one point. Before Cocofanto’s income was increased to $10K/s, this Brainrot actually outperformed it in value rankings.
Now, it sits in a middle tier. It is not weak, but it is also not dominant. Most players see it as a stepping stone Mythic rather than a final goal.
In general, players who already own several Mythics may skip it entirely, while newer high-level players often target it as their first serious Mythic purchase.
What Should You Prepare Before Going for It?
Before attempting to buy or steal Tracoducotulu Delapeladustuz, most players prepare in three areas: cash, positioning, and defense.
You should have more than the base cost available. In practice, bidding wars are common, and having extra funds gives you flexibility. Positioning near the red path also matters, since reacting late often means losing the chance.
Defense is the most important part. Usually, players who lose this Brainrot do so because they focused on buying it but not protecting it afterward.
Why Is the Name So Well-Known?
One reason this Brainrot stands out is its name. With 28 characters, Tracoducotulu Delapeladustuz is one of the longest names in the game. Only Brri Brri Bicus Dicus Bombicus is longer.
Most players struggle to pronounce it correctly, and this has turned it into a kind of in-game joke. It is common to hear players shorten the name or mispronounce it during matches.
This does not affect gameplay, but it does make the Brainrot more memorable than many others.
Is Tracoducotulu Delapeladustuz Worth Chasing?
In general, Tracoducotulu Delapeladustuz is worth chasing if you understand the risks. It is not a beginner Brainrot, but it is also not limited to top-end players.
Most players who succeed with it already know how stealing works, how bidding escalates, and how to defend a valuable asset. If you approach it casually, you will probably lose it.
Used correctly, it becomes a stable part of a long-term strategy rather than a flashy win condition.
